ehaoe
Dec 02, 2021Aspirant
Nighthawk Wifi Mesh System with Xfinity Gateway
I previously had my own modem connected to a Nighthawk Dual-Band WiFi 6 Mesh System (router with one satellite). I recently upgraded to the xFinity Gateway that has a built-in modem and router. I want to continue using my nighthawk mesh system. Is there a way to connect the gateway with the mesh system without enabling bridge mode, so I can continue using the xFi abilities?
When I connect the Nighthawk mesh router to the Xfinity gateway 2 wifi signals being emitted. I would prefer to have 1 wifi network with the mesh wifi capabilities. I do not want to bridge the two because I want to continue using the xFi software that Comcast offers. Does anyone know if it's possible to get these two products to become compatible without creating a double NAT problem?
I found an acceptable solution (option 3) here: https://community.netgear.com/t5/Nighthawk-Mesh-System/Nighthawk-AX-1800-MK63/m-p/2158564
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopNetgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you. - ehaoeAspirant
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
