Cotterk
Dec 08, 2024Aspirant
Re: MR90 Wired Connection Issues
I have been experiencing the same issue. I have 3 Ethernet wired devices. 2 are intermittent and is one always fine. Drivers are up to date
- Higgs22Aspirant
When the intermittent ones go down, can those devices ping out to 8.8.8.8 or 9.9.9.9 but not ping your gateway?
- CotterkAspirant
Im not sure how to do this
Cotterk wrote:
I have been experiencing the same issue.Same issue as what?
Your message seems to be disconnected from anything that went before.
I have 3 Ethernet wired devices. 2 are intermittent and is one always fine. Drivers are up to dateThose devices are? What symptoms do you see? Do the MR90's logs show anything untoward.
Just another user with time on their hands.
- Higgs22Aspirant
He's forking it from this locked post: https://community.netgear.com/t5/Nighthawk-Wi-Fi-6-AX-Mesh/MR90-Wired-Connection-Issues/m-p/2403640#M9496
- CotterkAspirant
Same issues as Higgs22 in the above posts
- CotterkAspirant
I may try that
I have 3 PCs on my network. 2 identical PCs (one has issues and one does not) Both are very near the router. The 3rd which is intermittent is 100 ft away.
The 2 identical PCs are HP desktops
The distant PC is an MSI gaming laptop
