Danny80916's avatar
Danny80916
Luminary
Aug 30, 2018
4k Streaming
I am at a lose I cant seem to stream 4k movies on vudu. I finally was able to get to stream a 4k movie earlier when i turned off QoS 100% When Qos is on I go to stream a movie and I get a network error has happened then the app crashs. I have messed with bufferbloat turned off the DumaGames turned things off and on . I would like to be able to use QoS tho.
    • Danny80916's avatar
      Danny80916
      Luminary
      Download speed set at 285 usally get 299 on speedtest Bufferbloat set at 73% 204
      have ran it with never on have ran it with DumaOS Classified Games on and off Have had bufferbloat set at never have had it set at always. I get the same results unless I turn off Qos also with QoS on blu ray player can't connect to sony to check for updates.
        Danny80916
        Luminary
        side note HDX movies play fine with QoS on soon as I change to UHD It pops up Network error has happened.
