Mikeowhite's avatar
Mikeowhite
adding additional wireless router to XR500
Last year I purchased an XR500 wirless router to replace my old wireless router.  Is it possible to use the old router as a range extender using a wired port to the wired input on the old router?
  • plemans's avatar
    what old router is it?
    Some have an access point mode you could setup.
    • antinode's avatar
      antinode
      Guru
         Almost any wireless router can be configured as a wireless access
      point, whether or not it has an explicit WAP-mode option.  However, if
      you want specific advice on your (unspecified) "my old wireless router",
      then you might want to reveal its maker and model number.
      • antinode's avatar
        antinode
        Guru
        > Netgear N750 WNDR4000 is the model
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual (at least).  Read.  Look for
        "access point" or "ap mode".  Prepare for disappointment.
           As I read its User Manual, unless the feature was added in some later
        firmware version, the WNDR4000 is too old/lame to offer an explicit
        WAP-mode option.  For an ad hoc scheme to deal with such models, see,
        for example:
              https://community.netgear.com/t5/x/x/m-p/1463500
           That's written for a Netgear C6300-as-WAP, but the steps are about the
        same for any other router (any make/model) which lacks a one-step WAP
        option.  If the router which you're reconfiguring has a WAN/Internet
        Ethernet port (unlike a Cxxxx), then leave it unconnected.
  • As has been mentioned, you can use it as an additional WiFi point, but not as an extender per se.
