Mygamertagsucks
Dec 08, 2021Apprentice
Bandwidth Allocation Issues After Firmware Update
Hey everyone,
Since I updated my XR500s firmware, I keep having an issue with QoS settings. After I updated the firmware, I performed a factory reset by inserting a paper clip into the factory reset button, as it seems to be recommended.
My issue is that when I go to the Bandwidth Allocation>Devices, I give my PlayStation roughly 90% of the upload and 85% of the download. If I then go to the Geo-Filter settings, when I return to the QoS page, everything is set back to their original values, which is usually 20.
I have tried going to Bandwidth Allocation>Gaming, and set it to 90%, and then click on any other tab, when I come back to Bandwidth Allocation, it's always returned to it's default values. I do not know what is causing this.
- Netduma-LiamNetDuma Partner
Are you clicking 'Update bandwidth' after changing the sliders? Otherwise, these changes won't stick.
Let me know if that's the case.
- MygamertagsucksApprenticeThank you for the reply.
Yes, I am clicking "Update Allocation" as well as "Save" on the box that opens up on the right side where you can slide the percentage up and down. I normally go to the PS4, use the slider to set my bandwidth to 15Mbps, which is roughly 90% of the upload. I click"Save" on the slider box, and "Update Settings" on the little flower page on the left. Then I do the same thing with the download settings. It never changes unless I check the Geo-Filter. There's nothing connecting to the network while I'm trying to play the PS4, so I'm not sure why the settings keep getting reset.- Netduma-FraserNetDuma PartnerI can't reproduce the issue you're having but if you're using devices instead of applications then come back to the page the view will default to applications. What web browser/device are you using to change the settings? Also you don't really need to give it that much bandwidth, it will use at most 1Mbps.
