raymondo111
Jul 28, 2025Aspirant
Cannot connect to most EU community servers in Valve Games
Having issues with connecting to most if not all EU community servers in CS2 and even other games. I am using a XR1000v2 and its firmware is upto date, and strict mode on geo filter is already disabled. I dont have this issue with my other networks, and i cannot find out how to disable this blocking of connections. The response the server feeds back, is App ID is not specified. The latency check also fails.
so ive found the solution. recently a online safety act was passed in the uk, which is interfering with the connection of certain ips which can only be bypassed via vpn etc.
- raymondo111Aspirant
- Netduma-FraserNetDuma Partner
Well done for figuring it out and thanks for posting the solution!
I believe ive disabled it, but im truly unsure of how to do it.
At the top of the page where you've added your device switch Filtering off/switch to Spectating Mode or just delete the device you've added there
yeah there are no devices added there, and i added and even disabled the filtering and tried it too, it still doesnt work
Have you disabled the Geo-Filter fully to see if you get the same issue?
