borngolfer
Sep 25, 2021Guide
Cannot connect XR1000-100CNS Router to Bell Home Hub 4000
I just bought an XR1000 Wi-Fi 6 router and have been trying to connect it to my Bell Home Hub 4000 via a cable that came with the XR1000. The internet would not connect and the "internet" light stays red on the XR1000 unit. I suspect it is the setting in the Bell Hub 4000 that is preventing the signal to go through. Any suggestions?
- Netduma-FraserNetDuma PartnerIf you haven't already you need to access the XR interface and go through the setup wizard to get internet
Thanks. Yeah, I did all that it still shows as no internet on the app.I tried all the different connection options on the app and still cannot get it to work. They are both WiFi 6 units so should be compatible.
- Netduma-FraserNetDuma PartnerSo you're doing the setup via the app? If you access the interface on a PC has the setup complete? Do you get a WAN IP on the System Information page?
The Bell home hub is a modem/router combo device.
If you''re wanting to use all the features of the Xr1000, you'd need to put the home home in passthrough mode or put the netgears IP address into the home hubs DMZ.
I have added the XR1000's MAC address into the HH4000' DMZ list and rebooted the XR1000 but to avail.
