3ijtKwij's avatar
3ijtKwij
Initiate
Aug 08, 2019
Can't do anything on DumaOS with XR500
Hi everyone
Somehow recently when I try to access my admin panel (DumaOS) I see the actual content for a few seconds and then it changes to the following message:
You are no longer connected to your router. If your router is rebooting then keep this page open as it will automatically reconnect to the router's interface when the reboot is complete. Otherwise please check your connection e.g. you are connected to the correct router.
Even though I am connected to the correct router and have internet access... I also tried to reset my router but I'm still having the same issue?
  • FURRYe38's avatar
    What browser are you using? Try FF or Opera.
    Wire or wireless connected to the XR router?
    • Netduma_Alex's avatar
      Netduma_Alex
      NetDuma Partner
      Try your browser's incognito mode/private browsing mode. If this works, you can clear your browser's cache and this should fix the problem.
