mhdavid87's avatar
mhdavid87
Certain types of traffic being blocked between Wired and Wireless Connections
Hello All,
I am having some issues with my XR500.
Certain types of traffic is being blocked and not working as it should between wired and wireless connections.
For example;
1. RDP (3389) only works between wired connections, it fails between wired and wireless which is extremely annoying.
2. Chromecast fails between wired and wireless connections as well when attempting to stream.
I have tried playing with the port forwarding/port triggering with no luck.
This is really starting to do my head in because it's on the same VLAN.
The only thing I can think of that could be causing it could potentially be the VLAN / Bridge Settings which I had to enable to get my NBN connection working out to the internet.
Any thoughts guys? I really need this resolved.
Thanks,
M
