SlayerPro's avatar
SlayerPro
Connection Dies Randomly With QoS Enabled
I am having a weird issue with my Nighthawk X500 Router. With QoS enabled, the connection will drop randomly. When this happens, I can play with the QoS slider and the connection will come back for a few seconds before dying again. Connection will drop on all ports and wifi. This doesn't happen at all with QoS disabled.
Anyone experience this?
  • FURRYe38's avatar
    What devices are you using when the connection drops?
  • Hi there - this is very unusual. What mode is your Anti-Bufferbloat set to when these drops occur?
    What is your total bandwidth? How much are you reducing the sliders to?
    • SlayerPro's avatar
      SlayerPro
      80%
      XR500 V2.3.2.40
      Arris TM1602 Cable Modem
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What's your physical setup, modem > XR500 > switch etc? Do you use PPPoE or VLAN?
  • FURRYe38's avatar
    Ensure cable between ISP Modem and router is of good quality. CAT6 is recommended.
    You might manually downgrade to v32, factory reset, power OFF the ISP Modem for 30 seconds then back on. After setting up minimal router settings, run a wired PC speed test with a PC and check speeds.
