SouthernGypsy's avatar
SouthernGypsy
Apprentice
Aug 30, 2024
Connection Test Failes to Give Results
I have our XR1000v2 set ro run a scheduled test every two hours and was working fine, let me monitor the connection over time. But for going on a week now the Speed Test and Ping Test (Under Load) fail to show any results and just show a - inside a grey cirlce down on the results section. The only part that shows any results is the center Ping Test section which shows an A in a green circle.
Anyone know what's going on?
Rebooting/Restarting does not solve it.
  • FURRYe38's avatar
    Post a screen capture of this please?
    What browser are you using?
    • SouthernGypsy's avatar
      SouthernGypsy
      Apprentice
      I'm using Firefox (newest version) but don't see what difference that would make, the browers is not loaded when the XR1000v2 is running most of these tests, except when I run one manually but the result is the same.
      I just cleared all the test off earlier (keep in mind these do not show failed, yet they show no results in many of the fields) but here is the last few it's done plus a couple of manual ones I just did....
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Has anything changed physically with your setup or settings wise prior to the issue happening?
