Okemo0351's avatar
Okemo0351
Constant Rebooting
I purchased my xr500 on June 01, 2018 so i am unable to contact support directly. Starting pretty much immediatly after buying this thing have I been plagued with the constant rebooting ( Once to twice a day, irregular times not limited to any particular use, meaning it doesn't always happen when on xbox or on pc, the router just randomly reboots). I have most all my deviced connected wirelessly to it but my xbox one x is hardwired. When the internet drops all lights on the router go out then enters back into its standard boot process. I have scoured the forums constantly and have attempted every possible step to remedy it it without fail. To be clear I have attempted the following:
~Factory Reset (Multiple Times)
~Constantly maintained up to date firmware (Currently running FV. V2.3.2.32)
~ I have changed Surge Protectors, I have tried a UPS, I have plugged directly into wall, I even completely changed the wall outlet.
~I haved tried both the MAC settings from the default address and Use Computer Mac Address
~I have tried both assigning dedicated IP's to all my devices and also tried letting it chose automatically.
~On the xbox my settings are set to energy mode (Instant on is NOT activated).
Also note that I have done full reboots on my xr500 and my primary modem after making each change. At this point I am ready to throw this 300 dollar paper weight in the trash. Since I use a network extender for my cell phone I am constantly dropping phone calls when this thing reboots.. All in all this router has caused me and so many others I have read about serious headaches. Is there any news or updates that can be shared with me that may ultimately fix this seemly widespread issue?
  • FURRYe38's avatar
    Any Wifi Neighbors or devices near by? If so, how many?
    What is the mfr and model of this wireless extender?
    • Okemo0351's avatar
      Okemo0351
      My ISP provider is Comcast and the Modem is the Arris Model TG1682G
      Channels: I have tried all them I stared out with auto then throughout the months tried switching between channels 1, 6, and 11. Currently I have it back to auto with Smart Connect enabled. But about a week ago I had disabled smart connect and was trying channel 11 and 2 weeks prior to that I had tried channel 6 and before that I was on 1. The most recent change a couple days ago I did a factory reset and changed the mac address from default to use computer mac and I left the wifi channels set to auto. In terms of issues with the current setup last night and the night before I experience a moment of severe performace drop and then the router rebooted.
      Neighbors: None live in the sticks no house near me
      Network Extender: Verizons 3G Extender,  Samsung (Model SCS-2U01)
        Okemo0351
        Also worth noting I am using the Netgear Wifi Analytics tool to test my signal strength and the apps recommended channel settings are 1, 11, 153, 165 which is what I was setting my preferences too when not in auto.
