Josh93's avatar
Josh93
Double NAT issue xr500 with nighthawk m2
Hello,
I recnetly moved out to the country side and was fortuinte enough to get 100mbs/25mbs via a mobile hotspot router through a local provider. I currently have MR2100 set up as an IP passthrough and disable the WIFI on it. Then I connected the device to my routers wan port and then connect our PC's and Xbox's via CAT6 etherent cables. I also opened up the ports for Xbox and other PC games I and my brother play. However i'm still getting a double NAT. From what I read on other forums i need to take the WAN IP and make it static, however the MR2100 doesnt have the feature to set a static IP address. Can anyone help me?
    • Josh93's avatar
      Josh93
      Netduma-Fraser thank you for the suggestion.
      I attempeted to do that, however once the settings were saved on the Nighthawk MR2100 the WAN IP on the Nighthawk xr500 changes.
      Do I need to turn off DHCP when doing this?
      Do I need to set a static IP on the XR500?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        You can keep DHCP on, on the XR in Internet Setup just switch it over to static - it will use the same details already and then that should prevent it changing and keep the DMZ active.
