Midvintersorg's avatar
Dec 17, 2019
DUMA OS not loaded yet
Hi!
This massage appears today when I reboot the router. Try to downgrade firmware and that works. But with the new firmware this occurs everytime. What do to? Have cleared cache on browser and reboot computer.
Best Regards
Henrik
  • Does this occur for the entire interface i.e. you can't access any page or is it on specific pages it happens? In System Information on the R-App panel options change the number of retries to 5 instead of 3 and then reboot the router please and see if that helps. What is your firmware version (the specific numbers)?
    • Midvintersorg's avatar
      Midvintersorg
      Guide
      I can do the standard setupwizard but when I try to login after that the screen "dumaOS not loaded yet" appears.
      Should I use an older firmware or should the router in for service?
  • I have the same issue and I see alot of it being reported today too.
    I tried .40 and still received the same error.
    Have it runnning on .32 now, but for sure will not work with .56 or .40.
    I guess will have to wait annd see what Support comes out with as this older version does not have the latest security updates in it.
    I hope it's a quick fix.....
