WhatitDo's avatar
WhatitDo
DumaOS keeps crashing and not finding Router
3.2.56 is software patch, its about 1 month old. It filters the internet but Duma Os is not found i have to reset the router from the app and it will find it be fine for 3 to 5 hours and if i check it its gone again.
This is kinda pissing me off as i search and do not see anyone else having this issue currently, seems on older patches they were.
  • now i cant even get it to load, i rebooted both the router and compter multi times, erased history, site data and cookies
  • FURRYe38's avatar
    Please downgrade the FW
    Firmware Version 2.3.2.40 or
    Firmware Version 2.3.2.32
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Are you accessing via routerlogin.net or the LAN IP? If the former try the LAN IP and see if you get the same issue.
      • WhatitDo's avatar
        WhatitDo
        its the same on both wont let me log on, goes to netgear showing how to clear cache
    • WhatitDo's avatar
      WhatitDo
      i tried both, and tried reinstalling router same issue not found
  • so it was doing this and now it just does not find router at all, i can clear cache and cookies and nothing
