Renovatio_Nixie's avatar
Nov 02, 2021
DumasOS not loaded yet
Hello,
I have recently purcahsed Nighthawk XR1000 pro gaming router. After one month when i trying to login into the router settings I am getting error 'DumasOS not loaded yet'. I did clear browser cache setting and also tried using different but still getting the same error.
Thanks and regards.
  • plemans's avatar
    Does everything else still work?
    Try firefox.
    I notice you have a 10.0.0.1 address.
    what's the xr1000 connected to for modem/gateway?
    • Yes everything is working. I am able to access net through wifi. Tried Mozilla, Edge, Opera but still shows the same error. Earlier I was able to access the router settings but now it gives the error DumasOS not loaded yet. No modem nothing direct connection from ISP.
      • plemans's avatar
        Have you tried a simple factory reset?
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
    Thank you.
    Renovatio_Nixie wrote:
    Hello,
    Thanks and regards.
