WacoJohn's avatar
WacoJohn
Luminary
Jul 20, 2018
Ejecting USB Hard Drive xr500
I have a USB 3.0 drive connected to my xr500 router.  It works perfectly on my home network.  I need to eject it, do a quick format on it, and reconnect it.  When I connected it the first time, I had to create one folder on it.  It was called USB.  My question is ... after formatting in on a PC and creating the USB folder, will it simply need to be reconnected to the router and then work as it does right now, or will I have to do all the GUI setup again?  Thank you in advance.
  • More than likely you would need to go through setup again as it would be like connecting a different USB to the router for the first time.
    • WacoJohn's avatar
      WacoJohn
      Luminary
      I was afraid of that.  I have only done it the one time ... and even that was with tech support on the phone.  I am not sure I remember exactly how.  I guess I will have to find something in the user guide or online.  If you can refer me to a tutorial .. that would be great.  Thank you for the reply, and I will close thread as solved on your next reply.  Thank you again.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        You might be okay if you recreated the USB folder. Setup would depend on which USB feature you're using. I don't have any guides specifically, I'm not too familiar with the feature as it's a Netgear own feature
