Pipodi's avatar
Pipodi
Tutor
Jul 22, 2022
Enable Traffic Prioritization on Escape From Tarkov
Hi guys,
I've just bought an XR1000 and I'm loving it so much. I've set up pretty much of the QoS as I want following the wizards. But I can't find guides/sources on how to prioritize games like Escape from Tarkov.
While I'm playing League of Legends, for example, under QoS tab I can see the two red lights next to DumaOS Classified Games and the number of packets sent/received goes up. But this doesn't happen while playing Escape from Tarkov. Also EFT is listed under Uncategorized:
On other hand, geo-filtering "works" as it detecs the server that I'm connected to, but sometimes not, it just detects the Battleye server and nothing else.
This is my PC:
and this is my XR100:
Can you guys help me figuring this out? Thanks!
  • For Traffic Prioritization if it doesn't have your game listed you can make rules for the ports the game uses, you should be able to find the ports it uses online and then you can make the rules. We haven't specifically tested the game which is why it is hit and miss, when you see that Battleye server add it to your allow list and see if it filters more consistently.
    • Pipodi's avatar
      Pipodi
      Tutor
      I don't know why my replies are not posted, am I moderated or what?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        I can see you've made 5 posts in total but I can't see what the other 3 are so I'm not sure what happened there. Can you repost what you said previously?
