shaanshivananda's avatar
Jul 16, 2019
Follow Up: How to use the XR500 as a second router? How do I avoid double NAT?
Hi all,
I recently posted about a Double NAT issue I was facing with the Netgear Nighthawk XR500 and the Xbox One X here 👉 https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/How-to-use-the-XR500-as-a-second-router-How-do-I-avoid-double/m-p/1773111
This is a follow up to that...
A little bit background:
My ISP has installed a modem/router (D-Link DIR-825) on the ground floor of my house where the internet is set up. I recently purchased a Netgear Nighthawk XR500 Pro Gaming Router and set it up upstairs and connected it via ethernet cable to the modem downstairs. Everything works fine, except I get Double NAT issues on Xbox and I'm sure this also effects the performance of other devices.
After doing some research, I was able to find out that I need to put my first modem/router into "Bridge Mode". However, the first modem/router does not support "Bridge Mode". I've heard of solutions related to DMZ, Port Forwarding, and disabling DHCP servers as well.
What I tried:
As suggested by Netduma_Alex, I found out my XR500 router's WAN IP and placed the IP in the DMZ settings in the Modem/Router Upstream. This fixed the problem temporarily and my NAT status was OPEN. A few hours later, I checked the Network settings on Xbox and it was back to "Double NAT". I checked the DMZ settings again and everything was fine. I even ensured that the router has a fixed/reserved IP which it does.
What can I do?
Am I doing something wrong? Do I need to disable DHCP for the first modem/router even though my DMZ settings are correct? I'm really running out of options here and I'm willing to buy a new modem/router as the first modem/router.
Next Steps:
If there is nothing else I can do, I do not mind purchasing another modem/router to function simply as a bridge. If I am purchasing a new modem/router to function as a bridge, which Netgear model do you suggest will work best with the XR500? Also which Netgear Modem/Routers support Bridge mode?
In India, these are some of the models available:
  1. Netgear R6400-100INS AC1750 Dual Band Smart Wi-Fi Router
  2. Netgear R6260 AC1600 Smart WiFi Router (Black)
  3. Netgear R6120-100INS AC1200 Dual-Band Wi-Fi Router
There are more models available but these are what I found first on amazon. Which do you suggest I purchase? And do all of these support Bridge Mode?
Please help
Netduma_Alex bacevedo
  • The next step I would probably suggest is putting the console in the XR500 DMZ and see if that resolves it.
    • shaanshivananda's avatar
      shaanshivananda
      Star
      Hi Fraser,
      Thank you so much for all the help! There was a confusion on my end which has been resolved by simply disabling "Instant On" on the Xbox One :)
      Have a wonderful day!
      Thanks!
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Great to hear that, thanks for the update! Don't hesitate to come back with any questions you may have.
