Raidrew
Jan 21, 2019Aspirant
Gaming lag and drops
Hello,
I buyed a new XR500 router to have better performances with my working Mac (I upload a lot of material and I'm far from the wifi station) and my PS4 (I experienced some minor lag, sometimes).
With the new Netgear router the Mac is working great, but I'm unable to play on the PS4. The first day everything went smooth, now I'm literally disconnecting and lagging every simple moment (I'm playing RDO).
I prioritez my PS4 but it doesn't work. With my 2013 Buffalo router and the same modem attached everything goes smooth without disconnections or lag.
Am I wrong on something?
I love the user interface, but as it is the product is useless.
- microchip8Master
Care to say on which firmware version? "the latest" is not a version
- RaidrewAspirant
My firmware version is V2.3.2.40
I check for updates and nothing is available. I have QoS set up to always, but if I disable it I will lose the main feature for this router.
- microchip8Master
Try disabling QoS for a test to see if you still experience these issues. If so, problem lies somewhere else
Raidrew wrote:
Hello,
You might get more informed answers in the section given over to your router:
Nighthawk Pro Gaming Routers - NETGEAR Communities
The DumaOS people who write the firmware are active there and probably don't see anything in this section.
What are you speeds UP and Down that you pay for?
Is the PS4 wired or wireless connected? Wired is preferred.
Raidrew wrote:
Hello,
- RaidrewAspirant
I have the basic Telecom router, with a speed of 60mbps download and 20mbps upload.
I can't use my PS4 wired, I'm 6-7 meters away from the router, in another room.
The sad thing is that, as I said, yesterday I tried with my old 2013 Buffalo router and I have no issue at all.
I haven't the time to test if it was the QoS.
