Alewi
May 13, 2022Apprentice
Geo-filter question! Xr700
Greetings netgear community,
I am playing efootball 2022 and they claimed, that they are using dedicated server now for matchmaking, unlike the old Pro evolution soccer versions wich use peer 2 peer for matchmaking! In the Geo-filter, I don't see that I am connected to any server( there is no server icon). I just see the players icons whom I am playing against, so for me it is still peer 2 peer! Do you have any information considering that?
Thank you in advance.
- Probably not lying, they may be keeping P2P open if you're unable to connect to a server for some reason e.g. if you're blocking it with the Geo-Filter
- Netduma-FraserNetDuma PartnerI suspect the server is misclassified as a player on the map, if you ping it, what does the domain name say?
- AlewiApprenticeHi fraser,
Thanks for the fast feedback as usual of you.
Every time I got connected to a different player, I got a deferent domain.- Netduma-FraserNetDuma PartnerCould you provide one for an example? It may be different servers you're connecting to or simply it may be that they have not yet rolled out dedicated servers to all regions
