Mustang1313
Sep 20, 2024Aspirant
Gigabit wifi speeds halved on XR1000
I'm sure that this topic gets touched on a couple of times a month at this point, but I cannot find a working solution to this issue. I just moved to a new house and we upgraded to gigabit download speeds. The issue is that my network download speeds seem to max out around 450mb/s. It does not appear to be the modem (which does not have router functionality), as I have tested the ISP provided router which provides 900mb/s at a minimum on wifi and ethernet.
Things that I have tried:
- Factory Reset router
- Disabling QoS as well as resetting distribution, Traffic meter, and congestion control (this did briefly bring ethernet speeds to 900, before returning to 400s)
- Manually setting expected speeds
- Removing all other devices on the network
- Using ethernet (Cat-6)
- Switching Wifi Channels and checking for interfering networks
- Updated to most recent firmware
All of the above were tested at a time that internet congestion would be at a minimum.
Clearly, there is still a setting that I am missing since speeds to the router are at least 900, and the router should theoretically be capable of over 4Gb.
If anybody out there has a fundamental understanding of DumaOS and this router, I would greatly appreciate your insight.
What devices are you using for speed testing?
Are you getting to spec speeds at the ISP modem or ONT with out the router connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What configurations are set under Advanced Settings/Advanced/Advanced Wireless?
Make sure the MIMO and Beamforming are enabled.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageWiFi Speed Info:
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
(old link with re-direct to new site URL)https://www.duckware.com/tech/wifi-in-the-us.html
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi- Mustang1313AspirantI'm testing using the downloaded speed test.net app on my computer and phone located maybe 4 feet from the router. Getting the full speed straight from the modem, yes.
Firmware: XR1000V2 1.1.0.16_2.1.25
Modem: Spectrum DOCSIS 3.1 eMTA
I am using CAT6 cables and set the channels to the ones you recommended.
So far it's still in the 400 range. Please let me know if you have any other ideas!- Mustang1313AspirantI should clarify: Ethernet speed has improved to 900
5G signal has not improved at all.
I've checked wifi and there is no interfering signal in my area.
- Netduma-FraserNetDuma PartnerGood questions above, also where are you testing the speeds?
