Thiscompanysux's avatar
Jan 11, 2022
HALF SPEED ON XR700
My XR700 router is blocking internet speeds less than half of what I am paying my ISP for (350 mb down actual vs 1000 mb down paid for) with the following specs:
  • Sparklight 1GB internet
  • Arris SB8200 2GB modem
  • Netgear XR 700 router
  • Wired imac
If I plug the ethernet cable directly into the modem I get roughly 915mb download speed. As soon as I wire into the router I get less than half of that (~350 mb download speed). I had Sparklight technical support come to the house for service (twice) and they confirmed it's a router issue both times.
Here's what I've tried with no changes in internet speed:
  1. Reset to factory settings
  2. New setup configuration (router noted that internet speed is ~950 mb download upon running the internet speed test built into the setup)
  3. Downloaded latest firmware
  4. Turned off all features (QoS, geo filter, etc)
  5. Tried to download specific firmware updates noted by the netgear community
  6. Reset back to factory settings, again.
I tried calling Netgear customer support but they want me to spend hundreds of dollars to fix a router I paid hundreds of dollars for. Any ideas netgear community? Or should I throw this hunk of garbage in the trash and get a Asus router?
Thanks
  • plemans's avatar
    are you only testing using the built in speedtest?
    Try testing it using the speedtest site.
    And try different servers on the speedtest site.
    Have you tried manually setting up a speed on the xr700?
    • Thiscompanysux's avatar
      Thiscompanysux
      Running speed test through separate test site and through ISP provider's site. I have manually set the internet speed without any change.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        How did you disable QoS exactly? If you didn't do it from the Anti-Bufferbloat/Congestion Control 3 line option menu in the top left of the panel then please do so and do a test again. Did you try the beta firmware?
