AlphaIOmega's avatar
AlphaIOmega
Hard reset on Netgear R8000
So my R7000 died last night. Press F to pay respects.
I went out to a second hand store and found an X6 R8000 router, but the last user changed the admin password, and Im locked out of changing any settings. Ive done the "reset" by holding the button for 30 seconds, and it still wont let me use the deafult passwords.
Is there any way of getting into this router to update the network name/settings?
    • AlphaIOmega's avatar
      AlphaIOmega
      I have tried the 30/30/30 method, and TFTP is not possible as the router does not get assigned an IP address :(
      • plemans's avatar
        The router doesn't get "assigned" an ip address. the router assigns the address. So if you read through the tftp process, you manually assign an address to your computer. Did you try it?
