CD56
Nov 29, 2020Aspirant
Hard wired XBOX one to router and receiving high Ping
I know i have read through the fourms a couple times and done a lot of things that wveryone has said, but here is my ditch effort to try and get some help instead of fixing it myself.
I have spectrum internet and upgraded services a couple months back to 400 Down/ 20-40 UP depending on the day, prior to upgrading i had 200/15. When i had the 200MBS i was wireless and receiving about 175 DOWN /15 UP with about 30-37ms ping to my XBOX ONE. Now with the upgraded I get between 400-450 DOWN /15-25 UP with a 80-95ms PING. I did hardwire the XBOX to the router to see if that would help and it didnt. I called Spectrum and they would not fool with my router, rightfully so not their hardware, but when they came out they were pulling close to 600 down/35 up and around 4-7 Ping off the modem. I upgraded frimware on the router, i have reboot the roter and modem more times than the law allows. please someone help.
If you direct connect to the modem, what ping times do YOU get? not the tech.
There's also a guide for optimizing settings for DumaOS. have you read through it a bit?
http://support.netduma.com/support/solutions/folders/16000090646
