dc2018
Jul 02, 2018Tutor
How do I disable WPS on XR500 router?
Just like the title says, how do I disable WPS via the Duma OS on this Nighthawk XR500 wifi router?
If nothing else, enable Smart Connect.
There is a manual for the XR500 somewhere at the end of this link:
>>>> XR500 | Product | Support | NETGEAR <<<<
See page 99.
- dc2018Tutor
You know I browsed through that manual you linked to, and there's nowhere that I can disable WPS. Am I missing it in plain sight?
Your mentioned smart connect has only this to say about WPS:
Router’s WPS PIN | Disabled while Smart Connect is enabled
Well, it doesn't necessarily disable WPS.
Where shall I ask about it? Maybe Duma OS forums. As it seems like a security flaw. Even my old dinky router had an option to disable WPS.
> [...] Where shall I ask about it? Maybe Duma OS forums. [...]
One Netgear possibility:
https://community.netgear.com/t5/x/bd-p/en-home-nighthawk-pro-gaming-routers
