dc2018
Jul 01, 2018Tutor
How do I disable WPS on XR500 router?
Just like the title says, how do I disable WPS via the Duma OS on this Nighthawk XR500 wifi router?
If nothing else, enable Smart Connect.
There is a manual for the XR500 somewhere at the end of this link:
>>>> XR500 | Product | Support | NETGEAR <<<<
See page 99.
- dc2018Tutor
You know I browsed through that manual you linked to, and there's nowhere that I can disable WPS. Am I missing it in plain sight?
Your mentioned smart connect has only this to say about WPS:
Router’s WPS PIN | Disabled while Smart Connect is enabled
Well, it doesn't necessarily disable WPS.
Where shall I ask about it? Maybe Duma OS forums. As it seems like a security flaw. Even my old dinky router had an option to disable WPS.
As I interpret it, if you enable smart connect, WPS won't work, and you won't be able to change it. No point in offering you the option to disable something that is already disabled.
Do you have smart connect enabled? You don't say. If so, enable it and see if there is then a way to disable WPS.
It is some time since I was involved in the beta programme for the XR500, but it is essentially an R7800 with expensive firmware. I use smart connect and see no WPS options.
The DumaOS people are pretty responsive to queries. They may be a better bet than lobbing a query into the maw that is Netgear's area for that device.
