Anirban's avatar
Anirban
How to setup ExpressVPN on Nighthawk Pro Gaming XR500 ?
Hi,
I am gonna get ExpressVPN but can anyone tell me how to install ExpressVPN on my Nighthawk Pro Gaming XR500 router ?
  • You'll need to obtain the OpenVPN configuration file from them, then you can paste it into the advanced section of VPN Setup.
    • Anirban's avatar
      Anirban
      But doing so will it void my routers warranty or not ?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        No of course not, it's a feature on the router, we wouldn't implement anything that would void the warranty.
