Godrik's avatar
Godrik
How to test if Hybrid VPN is working for "Only VPN these Services"
I was able to successfully set up my VPN Provider under Hybrid VPN on my XR700.
I only want to use the VPN for torrents. I was able to add my PC under the "VPN Traffic" tab, and I selected "Only VPN these Services". I added the port used by the uTorrent app.
I was able to succesfully test that the VPN is not being applied by default.
How do I know for sure that my torrent activity is being correctly routed through the VPN? Is there any way to test this?
  • schumaku's avatar
    schumaku
    Sniffing for suspect traffic on the WAN side of the router on the ports/protocol your torrent software is active on.
    • Godrik's avatar
      Godrik
      What is "sniffing" and how do I do it? What does WAN side mean?
      • Netduma_Alex's avatar
        Netduma_Alex
        NetDuma Partner
        How did you figure out which ports your torrents are using?
        You can usually set which ports you want your torrent software to use from within the software itself, so check inside the software that the selected port matches what you put in your VPN.
