EnVy_Hype
Jan 07, 2019Aspirant
I don't have hybrid vpn
I have recently upgraded to the the latest firmware. I live in China and I waited so long for the newest features. I am running the latest software, I have ping assist and auto ping. It doesn't have hybrid VPN. I need help asap. I am running on the XR500 V2.3.2.40
Hybrid VPN is selectable between Network Montor and System Information:
EnableBlock Traffic If VPN DisconnectsVPN SETUPInformationLogsProvider N/A Username N/A Country N/A City N/A Protocol N/A Status No VPN configured - Netduma-FraserNetDuma PartnerIt may be that due to your location it has been disabled, instead you should have the option to use a specific Chinese gaming VPN in the Settings
- EnVy_HypeAspirantI can't see it, and I don't have it.
could it be that VPN is not supported in China?
- Netduma-FraserNetDuma PartnerI believe it's triggered by the interface language, change it to your native language, does the Chinese VPN appear in settings then? Also didn't see a screenshot of settings
- EnVy_HypeAspirant
It has vpn service but I had it in all previous versions and no vpn client.
- shijinyingInitiate
I see Netgear's point, VPNs are a big grey area in China and Netgear wont want any trouble by offering its Hybrid VPN feature. The only way around this problem I see is running the VPN separately instead on Netgear.There are alot of vpn for china available.
