Felix24343's avatar
Felix24343
IKEv2 with MR1100
Hey all,
I was wondering if anyone had used the MR1100 to connect to VPN on IKEv2? I have had issues connecting to my work VPN using this protocol and wondered if anyone else had this experience?
Can netgear advise if this protocol is supported on this router?
Cheers,
Felix
  • Hi All,
    Further to this I have also tried using my old AC800s and have got the same issue of trying to connect to my work vpn.
    I have tried the following with both Modems:
    VPN Passthrough
    DMZ mode to static IP
    My work vpn uses UDP ports 500 and 4500 but I cannot connect.
    It cannont find in the web interface anything to make sure these ports are open.
    I have been able to use an old huwawei modem and connect fine.
    Any help appreciated.
    Cheers,
    Felix
