Tkbuc
Nov 29, 2022Guide
In Game Latency
Hi everyone,
Attached is a screenshot of in game latency details for an online game. I just factory reset my router and have a 1GB modem via Spectrum. Everything is working great. Every once in a while my Latency will shoot up to 800 but then go back down to the 60/70/80 range. It's doesn't happen consistently or frequently, but I'll notice it every once in a while. I thought it is because I am using Bitdefender VPN so I turned it off but it still happens occasionally. Is that normal to happen every so often? Can anyone tell me what the data in the screenshot is telling me as I'm not that familiar with the readings?
Not much to go off here.
Is this regarding a NG product? If so, need more details here.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.- TkbucGuide
Im using the Nighthawk XR1000. The screenshot is the ingame latency data from the game client.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Are you wired or wireless connected to the router? Wired is preferred for gaming.
