Compoza_'s avatar
Compoza_
Luminary
Mar 13, 2021
issue entering the DNS
Hi! The router doesn't save the new DNS numbers I entered. When I check my DNS on my computer or on PS4, it just shows the ISP's DNS, not the one I would like to use.
It's google DNS: 8.8.8.8, 8.8.4.4 I'd like to use. Any ideas?
Regards
  • You enter the DNS on the router itself, devices themselves will show the router IP as the DNS as they connect to that first and then will use the DNS you set.
    • Compoza_'s avatar
      Compoza_
      Luminary
      Could you explain it in easy english, sorry, my english is not the best :smileylol: :manembarrassed:
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        It will use the DNS you have set on the router don't worry :)
