BanditMask's avatar
BanditMask
Losing Internet connection
My new router consistently loses connection to my ISP cable modem.
Logs
[DumaOS] DHCP lease change., Thursday, March 07, 2019 17:15:56
[DumaOS] DHCP new event., Thursday, March 07, 2019 17:15:56
I've read through posts, disabled Xbox Instant on, hard set IPs, reduced range 200-254
any fix, it seems to be a reoccurring issue among others on the forum. I'm using the latest firmware
  • FURRYe38's avatar
    What FW is currently loaded?
    You might revert to v32
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        You said you set static/reserved IPs was this just for your LAN devices? If so I would recommend doing it in Settings > Internet Setup.
