Noah-needs-help
May 31, 2021Aspirant
Missing settings in xr450 DumaOS
I’ve been seeing you tubers and other people go over the different settings in DumaOS and I have the xr450. Settings like ping hotmap, connection benchmark, addblocker traffic controller, and rapp store aren’t there for me. Also DumaOS just looks a bit lower quality and overall less options and runs kinda slow. I’m on the newest firmware that I know of and it doesn’t say I need to update. Is there anyway to fix it to where I get these settings. I’ve been having trouble with internet and don’t know where these parts of DumaOS can be found.
- Netduma-FraserNetDuma PartnerYou can find the DumaOS 3.0 beta here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR450/td-p/2071197 which will bring you the majority of those new options. I would recommend doing a factory reset after the upgrade for a fresh install.
- Noah-needs-helpAspirantdo I do a factory reset in DumaOS after downloading the new firmware update or do I need to do the pin on the back of the router?
- Netduma-FraserNetDuma PartnerOnce you have upgraded you can do a factory reset from the interface, no need to use the pin
