Fibtls18's avatar
Feb 24, 2018
moderate Nat xr500
moderate nat with xr500 and cod ww2 ive done everthing from resetting router and network settings to wireless and wired connections can not get an open nat on ww2. Something is fishy as ww2 tells me they tried to open port 3074 and failed, but on my router settings under upnp is says 3074 open.  any one else having these issues?
daniel
  • Hi Daniel, if you put the console IP from Device Manager into Settings > WAN Setup > DMZ you will definitely have an open NAT. Yes CoD can give incorrect readings. If you have a device selected on the Geo-Filter set it to Spectating Mode until you get onto the game and ready to search for a match. Then switch back to Filtering Mode for when you're about to search for a game.
  • also i have read the posts about false readings while booting up the console and geo filter enabled. could this be the case? if so how do i disable the geo filter while booting up? sorry for the questions i have only had the router 2 days and still getting used to it.
    daniel
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      • Fibtls18's avatar
        Fibtls18
        Guide
        That fixed the wireless console. thank you! now on to the wired, this one still says moderate even after clicking spectating mode. Any way to get around this moderate nat on a wired conection?
        daniel
  • I've also read that if you two consoles people have figured out to put Nat Filtering to Open Instead of secure when playing CoD.
