NanaO's avatar
NanaO
My XR500 LED’s white but no internet connection
I had issues with my geo-filtering so I decided to do a factory reset on my router. Now I can’t get past through the config stage and it won’t detect an active internet connection.
  • Skip through the wizard, reboot the modem, wait 2 minutes then reboot the XR, wait 4 minutes and see if it gets internet then
    • NanaO's avatar
      NanaO
      All the options I have requires an active connection, there’s nothing that can be skipped
      • FURRYe38's avatar
        Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
        Has a power off for 1 minute then back ON with the ISP modem and router been performed?
        Turn off and unplug modem.
        Turn on computers and rest of network.
