MRS911
Mar 26, 2020Guide
need help for netgear xr500
Hello
I have been using Router Netgear XR500 for a long time,
but I don`t know what the correct settings should be used in order to enjoy playing online.
Sometimes I encounter a delay in response in some games.
I am using bridge mode from Huawei HG8245Q ISP router and
my internet speed is 300 download and 80 up .
Here are in attachments the settings that i`m using now and I don`t know if need to changed or not ??
I need your help.... thanks.
https://i.top4top.io/p_1546oehfb2.png
https://h.top4top.io/p_1546r5lev1.jpg
https://j.top4top.io/p_1546gxkqm3.png
https://b.top4top.io/p_1546dztlg7.png
https://k.top4top.io/p_1546f26t54.png
https://l.top4top.io/p_1546vmq855.jpg
https://a.top4top.io/p_1546saom16.png
https://c.top4top.io/p_1546oqjkg8.png
- Does the console report an Open NAT? If so then the game will have an open NAT also, it will most likely be the Geo-Filter causing a misreading. You could use either option but I wouldn't suggest using both, probably DMZ would be more secure/considerate of your other devices.
- Netduma-FraserNetDuma PartnerI would recommend you go through our optimal settings guides here: http://support.netduma.com/en/support/solutions/folders/16000090646 then if you have any issues/questions we can go from there. Please note that due to the global issue going on at the moment that services are under heavier load than usual and so can result in higher than normal pings/lag.
- MRS911Guide
my problem before 3 months ago , just i want know about my settings is good or not ?
- Netduma-FraserNetDuma PartnerYour settings look okay but you've not shown everything that could affect the connection so I couldn't say for certain. By looking at the guides you can fine tune those as well as get a better understanding of how the router works.
