GLO
Jul 27, 2019Tutor
Netgear password reset & still won’t login!
Hi,
Is there a problem with Netgear login?
I reset my password and naturally can’t use the previous password, but even after creating a new one I still can’t get in!
Help please!!!
Help please!!!
GLO wrote:
Is there a problem with Netgear login?Login to what? Your router's graphical user interface (GUI)?
That is a local address for the GUI on your XR500. It goes nowhere near the Internet. (You should even be able to get in without being plugged into the Internet.)
GLO wrote:
I reset my password and naturally can’t use the previous password, but even after creating a new one I still can’t get in!I'm afraid "can’t get in" could mean many things.
What are you doing and where does it go wrong.
By the way, it may not matter, but you have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get better and quicker replies, and find other answers, over in the appropriate section:
Nighthawk Pro Gaming Routers - NETGEAR Communities- GLOTutor
That is mynetgear.
Have you set up an account there?
It does not use the same password as your router's GUI.
GLO wrote:
....it still errors out.What does "errors out" mean? Times out? Rejects password? Something else?
