TypicalSwab
Feb 21, 2023Aspirant
NETGEAR XR1000; Location
Hi,
I've recently moved in to another Property (8 days here) and have connected my XR1000 to the existing Modem/ISP here.
If I use Google Maps to identify my location on my PC, it shows me a pin about 58 mins drive from where I am.
If I use my iPhone, connected to the WiFi, Google Maps and other Apps locate me at my old address.
Just wondering what I can do to fix this.
Thanks
- Netduma-LiamNetDuma Partner
If you connect your PC/Mobile device directly to your ISP router/modem, do you still observe the same behaviour?
- TypicalSwabAspirant
Thanks for getting back to me.
I've just tried this and no, the behaviour doesn't apply if connected directly to the ISP's router.- Netduma-FraserNetDuma PartnerHave you got your PC added to the Geo-Filter?
