Vauxy
Jan 08, 2022Aspirant
Netgear xr1000 traffic controller netduma os
I have reset my Xr 1000 gaming router and my traffic rules have disappeared even though they are still running on the right hand side. I can not delete nor edit my rules. I use these to limit my childrens times on their devices
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
Thank you. - Netduma-LiamNetDuma Partner
How exactly did you reset the XR1000, via holding the reset pin on the back for thirty seconds, or through the interface?
Is information in the panels on the right-hand side updating live or is it more a history of previous activity?
- VauxyAspirantI reset through the reset button on the back of the router. Google chrome was recently updated on my computer would this cause an issue? Yes the panels on the right side are live.
Thanks for your response- Netduma-LiamNetDuma Partner
OK, and were you prompted to complete the initial setup again after resetting the XR1000?
I don't think the browser update would've caused an issue, though it might be best to clear your cache after the update and reset of the XR1000 as that can cause issues occasionally.
