Mr_Clow
Oct 25, 2020Tutor
netgear xr500 firmware 2.3.2.66
Last week I updated to new firmware 2.3.2.66. After that, I keep getting a network connectivity issue; my net keeps getting disconnected and reconnected, and the speed keeps dropping. After this issue, I change the router to a different one, and the net is completely woking even I connected to isp, and they checked everything.
- mr_taintAspirant
in b4 they tell you to check the power cord
- Netduma-FraserNetDuma PartnerPlease try the 3.0 beta and then do a factory reset to start fresh and see if it continues. https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
- Mr_ClowTutor
I updated to new firmware still the connection is unstable keep getting connection issues
- Netduma-FraserNetDuma PartnerDid you do a reset after upgrading? Is it only WiFi or wired devices that are affected?
