mikew2
Jun 13, 2023Aspirant
Netgear xr500 resets randomly
Hi,
I have the Netgear XR500. It will completely reboot, seems like this is a common issue. I have followed the following troubleshooting: Factory reset. Plugging the power cable directly into the wall.
Appreciate any help.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channel configurations are currently set on the router?
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router- mikew2Aspirant
Firmware V2.3.2.134
Calix Gigapoint 803G
LAN Cable is CAT6.
The issue is only since switching to this router. It is temping to just use the ISP router since it never disconnects.
I have set the DHCP range between 50 and 254. Reserved IPs for all devices.
Channel configuration: Smart connect enabled. Channel Auto for 2.4GHZ and 153 for 5GHZ
- Netduma-FraserNetDuma PartnerWhen this happens it's usually some sort of power issue so try using a different power adapter. However, looking at the log it's unlikely it's actually rebooting but more likely disconnecting. In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
- mikew2Aspirant
Ok. I confirmed under LAN Setup that the DHCP range is 50 to 254. I have every device reserved IP from 1 to 10.
For clarification. When it disconnects it is every device disconnecting, Wireless and LAN.
I'll try rebooting from the interface and see. The disconnects are a couple times throughout the day. It disconnects every device, wireless and LAN.
Please set the smaller DHCP IP address range.
Be sure that any Reserved IP address that is set ON the router is with in this smaller IP address range.For any STATIC IP address configurations set ON devices, should be outside of the smaller IP address range.
