LouMano's avatar
LouMano
Netgear Xr500: sliders does no affect to download speed
So I have purchased the Netgear Xr500 after many years of use on the NetDuma R1. I have my download speeds set up which I’m currently getting 329 Mbps download and 12 Mbps upload. My Xbox gets the majority of the internet but when I lower my sliders for the download, nothing seems to happen to my download speed it will stay the same. I am looking for some help or advice on this matter. Thank you
  • Hi Lou,
    Two things to check. First:
    1. Set the mode to 'Always' and try again. If you had it on 'High Priority Traffic Detected' mode it will only apply the limits when a game is being played
    If that doesn't work, then:
    2. Disable IPv6 if you've enabled it. Also, if you're using PPPoE, enter your credentials in your modem instead of the XR500
    • LouMano's avatar
      LouMano
      Hey thank you for the advice, it is working. I am currently having trouble with my NAT type on Xbox now tho. It won’t register, I have UPNP disabled and everything port forwarded. It seems when I have it on filtering mode it will go into not registering my NAT
      • LouMano's avatar
        LouMano
        Also I am having problems joining friends party chat as well, it will not let me connect. I know when I had my Linksys I never had this problem
