Zendorea's avatar
Zendorea
Network bounces at 10:05 AM and PM EST Daily
So i have a weired issue. Router seems to be Bouncing at the same time daily. I worked with my ISP to narrow this down to the equipment plugged into the Cable Modem.
Wanted to see if this has been an issue for others as well and if there is a patch in the works
  • Go to Settings > Monitoring > Connection Status, does the DHCP Lease/obtained indicate that it is one day long?
    • Zendorea's avatar
      Zendorea
      Hi,
      Thanks for the response. I had to Downgrade the Firmware to V2.1.0.6 to fix the issue. Network is now stable after doing so.
      I Can also Confirm that the DHCP lease was not the cause as the bounce occured exactly 12hrs apart daily and the DHCP renew from the ISP/Cable Modem was a week
