Mar 01, 2022Guru - Experienced User
New - XR700 Firmware Version 1.0.1.48 Released
Security Fixes: 02/16/2022
- Fixes security vulnerability issues.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
NOTE: This version of FW does not have DUMA OS 3.0 included.
Download Link: https://www.netgear.com/support/product/XR700.aspx#download
Firmware Update Instructions:
- To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/XR700.aspx#docs
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: It's recommended to factory reset and setup from scratch after applying FW updates if problems are seen.
This article applies to:
Let us know how it works for you...
- Thank you, we still waiting for new Beta 3.0. I hope you guys give it to us soon.
- xfalaxTutor
It is incredible that with each update the netgear people do not fix the deactivation of Vlan ...... every time they update I lose internet because they deactivate the Vlan box.
Since the betas I've been reporting this problem and it's still the same.
Not to mention my XR700 which is gathering dust because it gave me more trouble than joy.
Since the update to 1.0.1.48.
1) I have lost LAN connection to the printer.
2) Download speed is unstable typically 300s Mbps (I have gigabit service from Xfinity, 800s upto low 900s on good days).
3) Slower DumaOS interface with random crashes while configuring it.
Yes on factory reset (like 5 times).
Any new updates soon?
- Netduma-FraserNetDuma Partneronlywiseman the only difference on this version is security fixes so I couldn't see how it would cause those issues at all if nothing else in your network changed. If you downgrade does it work as expected? We provide all updates on firmware progress here: http://support.netduma.com/en/support/solutions/articles/16000132677-dumaos-firmware-progress
