ajkron's avatar
ajkron
Guide
Dec 14, 2018
night hawk xr500 slow speeds all of the sudden
wireless speeds were great then all of the sudden they went down to 30-40.  was getting 300 plus.  when i connect to my modem i can achieve 300plus.  i am on uverse gig service.  i have tried all the suggestions on this forum but issue still unresolved.  any help would be greatly appreciated!!
  • You should get 3 months support with them I think.
    A possible trick is to give the XR500 the MAC address of your previous router. Sometimes the ISP has trouble negotiating with a new router in which case that fixes it in some cases.
  • FURRYe38's avatar
    What FW is currently loaded?
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
    • ajkron's avatar
      ajkron
      Guide
      Thanks for the reply. I'm at work but will get you all the info this evening.
    • ajkron's avatar
      ajkron
      Guide
      FW  2.3.2.40
      Mfr and model# of the ISP modem:  pace 5268
      connecting on auto but have tried various channels with no success
      roughly 10 wifi neighbors nearby
      have 2 unverse tv's hooked up to my uverse modem.  thats the only thing plugged into isp modem due to the fact that it buffers if i plug into nighthawk
    • ajkron's avatar
      ajkron
      Guide
      Modem Combo Units:
      Couple of options,
      FW  2.3.2.40
      • ajkron's avatar
        ajkron
        Guide
        this is getting a little frustrating to say the least.  now my router speeds are showing 42 down and 360 down.  any input would be greatly appreciated.
