SpencerSda's avatar
SpencerSda
Nighthawk AX5400 Random Factory Resets
I have had this router for about 5-6 months; however, this is now the 4th time i have to fix my router.
for some reason the router after i try to login into it fails, this is very rare but when it fails, its factory resets my router.
Why is it resetting my router to factory default, I can't have this as i have a private server running at home for work with confidential information, it resets everything including my internet no longer has passwords or custom names.
i also have to reconfigure my server every single time this happens.
How can i fix this? so my router will function like it suppose to?
This is the error i get when i try to access my router after this, i have to go to the back of my router manually and hold the button in to reset then set everything up again.
which i have previously and it took me 30-40 minutes to setup again, since i have to reconnect everything in my house.
but in the meantime, i have turned my server off, to see if yall know what i need to do to fix this.
Thanks
Spencer
    • SpencerSda's avatar
      SpencerSda
      i have the XR-1000
      i hope this is what you are asking for. 🙂
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What web browser do you use? I use MS Edge with mine. BE sure to clear out all browser caches before entering the routers web page.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    If you have a v1 XR1000, you might update FW: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-XR1000-Firmware-Version-1-0-0-68-Released/td-p/2312239/jump-to/first-unread-message
      SpencerSda
      Sadly, i can't access anything from the router, after the reset i have to reset it again, to get access to the router,
      I have charter internet. 350mbs and 15mbs upload
      cable is cat 6
      couldn't tell you the last time i did a firmware update,
      and my Ip from the router isn't a 192.168.1.1 is ###.133.4 not going to put it all in since that will give my exact location
      I have set the Router up last 3 times by the phone app; the computer setup doesn't work properly. or i don't know how to set it up that way.
      • FURRYe38's avatar
        You'll need a ethernet connected PC to set up the router properly and probably get the fw updated. After you press the reset button, connect a ethernet connected PC or laptop to the back of the router and use MS Edge or Firefox and navigate to 192.168.1.1. This will being the setup wizard process.
        192.168.1.1 is the routers IP address and web page access address. The 75.x address is the WAN IP address the router gets from the ISP modem? What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? This won't give location.
