Thorlake's avatar
Aug 15, 2018
Nighthawk has stopped Broadcasting Wifi
Hi,
Installed the XR500 and it initially worked flawlessly...for a couple of days. First the 5GHz Wifi network disappeared but the 2,4GHz stayed up. But now both have gone. It is also only the 2,4GHz white light on the XR500 that is lit (First three LED:s all white) and yes, the button lights ontop of the box also white. I have done a soft reset, a factory reset and restarted the modem.
The the OS on the router says everything is fine and broadcasting. But I cannot see the WiFi network on any of my devices. (Iphone, Laptop, TV etc)
IT works LAN connected though. AND I have the latest Firmware.
I cannot find anyone else with the same problem on Google or on this forum.
What should I do???
Thanks!
    • Thorlake's avatar
      Thorlake
      Tutor
      Yes, I even disabled it, did an "Apply" and then Enabled it again too see if it did anything. But nope.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Double check thats still disabled after your last test, then disable beamforming and mumimo and see if you can see it
