Marv921's avatar
Marv921
Nighthawk xr1000 blocks fall guys
Hi, Nighthawk xr1000 blocks fall guys. Any ideas?
  • michaelkenward's avatar
    michaelkenward
    What is fall guys? What happens?
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    This game on PC or game console?
    How is the router configured?
    • Marv921's avatar
      Marv921
      Hey mates, im playing on ps5. I have everything perfect connected and the settings are also ok. Im working im IT…
